跳转到主内容
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
What does E2 mean and how to fix it
define E@ and how to fix it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
John Girtman, error code E2 is indicative of a shorted thermistor. The thermistor is a component that changes its resistance according to temperature and is monitored by the control board monitors to regulate the operating temperatures. . If the control board does recognize a certain range of resistance of the thermistor, the control board will stop the dryer and display "E2". Start by replacing the thermistor
这个答案有帮助吗?
得分 2
2条评论:
Ok I replaced it still E2flashes
完成的
@ROBERT THOMPSON almost a 7 year old question :-) What is the exact model number for your washer?
完成的
添加一条评论
On kenmore 110 series, including he models, an e2 by itself is either lid lock or the thermistor at the water inlet. The lid locks on these are surprisingly fragile and hard to test so dont take the mechanism off unless it fails a continuity test from the plug. Thermistors on the water inlet are easy to test when they go bad they almost always have zero continuity at any temp.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Girtman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 5,052
