跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Replaced the batt, now power button, mute, volume and vibrate broken
I went through the battery replacement process on my 5s, most of the phone functions are fine, however, none of the external buttons (power, mute switch, volume) do anything, and the vibrator no longer vibrates - is there anything common to all of them?
Any ideas?
Many thanks
Justin
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks folks, I'll have another look tonight - I had a few issues getting the screen connectors seated (initially had lines down the screen - fixed by re-seating) so may well have disturbed the connector for the flex cable too.
I did a similar repair on my wife's 4s when the power button failed, so know how fun replacing that kind of cable is!
I'm also having some odd issues where the phone seems to have ditched all the certificates and privacy settings, so now the calendar app is unable to access the calendar accounts that I have configured. Given its the IOS app, there is no way to add it back in under the privacy settings. The touchID sensor works, but has also forgotten all my fingerprints, so its almost like I've tripped some of the protection around stopping touchID hacks.... I'll do a restore once I sort the button problem.
Thanks again for all the help!
justin
完成的
添加一条评论
4个答案
已选择的解决方案
Hi Justin,
All the functions that stopped working are due to one single cable, the PMV flat cable, or "upper component cable." Here's the iFixit guide that shows you how to replace it. It also has the link to the needed replacement flat cable. That's in case you tore the cable.
However, use it first to see where this cable is plugged onto the board, and try disconnecting it then reseating it. Be careful and very gentle otherwise you may break the connector on the board or something around it. This particular cable is a PIA to plug back in, which is why you may have done it improperly during the initial repair.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
It sounds like you tore the flex cable underneath the battery, which is responsible for all of those. It is a bit difficult to replace, I don't believe iFixit has a guide but you can look it up on Youtube. Most suppliers sell it as the "power/volume flex."
这个答案有帮助吗?
得分 2
添加一条评论
Check the flex cable, does it look damaged?
The battery is glued over the flex cable and it can be damaged, although i've never seen that happen before.
I'd try another flex cable, test it before installing to confirm the problem. Then you've just got to remove the logic board to get access to the screws for the flex cable. It's not difficult to install if you've repaired phones before.
Also, does your home button still work?
If your home button does not work as well I suspect you have damaged the logic board from prying the battery.
这个答案有帮助吗?
得分 2
添加一条评论
I'd bet the volume/lock flex is damaged, that is common among those parts, try plugging a new one in before installing it and see if that fixes the problem. They're kind of a bear to get the lock button right the first time you do one.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Justin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 140
