跳转到主内容
加入维修社区 - 创建账户
2013 年 11 月发布。32 GB 闪存。8 GB 内存。四核处理器。通过型号 EGQ307 识别。尺寸 7.58 x 4.60 x 0.45 英寸。分辨率 1080 x 600。电池续航时间 4.5 小时。
Why Is My Battery Not Charging?
My battery doesn't seem to be able to charge, or hold a charge. What can I do to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
3条评论:
my family received 4 of these for Christmas 2014 and this had been a problem for all of them for a few months - could all of their batteries really need replacing or is there another issue that it could be?
完成的
It is not the Battery. The USB charging port is cheaply made. Either you need to get a better tablet, or you can replace the port. Remove the back, pull off the black fabric tape and unscrew the screws. Lift up the tech board and you will see that the port isn't even connected, so it will be very easy to replace. All you need to do is buy a new port and replace it.
完成的
It is the port.
完成的
添加一条评论
2个答案
If you have been having trouble with battery not holding charge and now it does not charge your battery needs to be replaced.
这个答案有帮助吗?
得分 0
3条评论:
Here are instructions on how to replace your battery: Ematic EGQ307 电池更换
完成的
完成的
Id say you have the same issue. Maybe you can claim warranty on them
完成的
添加一条评论
Mine turned on for 3 weeks and nada no charge. .. Anyone else have the warranty contact information?? It'd. Be greatly appreciated
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonathan Scinto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 3,439
