跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Screen will not function no matter what
Hello, I have an iP;hone 4s that suddenly had the screen black out while being used, the vibrate still functions so I know the device still powers on. I have tried everything I have found so far, disconnect the battery for a harder reset, doing a Power + Home reset, and reconnecting the screen connectors. Nothing has worked. I even put a different screen on the phone and that did not work either. The connectors appear to be fine, no damage. Does anyone have any idea what might be wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Cheeseman93, could be that the actual backlight has failed. Replace the display assembly and see if that fixes it. If it does not, you will have to take a closer look at the backlight circuitry on your logicboard. It is always possible that one of the backlight filters etc. has failed.
这个答案有帮助吗?
得分 2
2条评论:
I think it might actually be a motherboard issue like you had said. I've done some pretty complicated repairs but reconfiguring an iphone motherboard is not one of them. I assume its more than your average soldering iron.
完成的
Just need a good microscope and a good soldering station. With a bit of practice on an old board, you can accomplish this too. I suffer from OPV (old people vision) and have the aging tremors, but still manage. Go for it...:-) Consider posting some images of your board from around the LCD connector. Lets see if we can spot something odd. Use this guide 在已经存在的问题里加入图片 to add images.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 71
