LG 60PZ950 no image but sound ok
I have a TV LG 60PZ950 (march 2011)
The color started given out but now hardly any image is visible but the sound is ok.
How can I fix it? or what part to change?
this is the image we see
the board pictures
Cindy, thank you for the pictures. Yes as previously suggested this could be caused by the Z-sus Board. I attached an image of where to check and what to check for. You will need a multimeter for that.
The board itself is available at places like this. If you are handy with a soldering iron, you can also try and replace the transistors on the board itself. Those are FGPF4633 IGBT's and are available at Mouser.com or you can buy a repair kit from here.
这个答案有帮助吗?
i removed all the boards and resoldered, then applied a heat gun on every board and it worked.... now i have all HDMI ports working, and no issues with colour
这个答案有帮助吗?
what is the cost for the part?
这个答案有帮助吗?
Debbie Freeman what parts and it will depend on where you are located.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 2,192
4条评论
Cindy, can you elaborate on this "color started given out"? Do they look faded or just very dark image altogether?
由 oldturkey03 完成的
Dark image all together
由 Cindy 完成的
Sounds like your backlight is going out but it is hard to tell without actually seeing it. any chance you can post some images of what you see.? 在已经存在的问题里加入图片 A dark picture can be caused by a bad Z-sus board If you can post some images of all of your boards. For that you will have to take the back off.
由 oldturkey03 完成的
Sorry about the delay, we moved and got really busy. I have added the pictures you asked.
Please let me know if you need anything else
由 Cindy 完成的
