跳转到主内容
加入维修社区 - 创建账户
Acer Aspire 8920 是 Acer, Inc. 于 2008 年发布的一系列笔记本电脑。Acer 是一家总部位于中国台湾新北市的电子公司。8920 机型作为 Gemstone 系列的一部分发布,是 Acer 生产的首款配备 18.4 英寸屏幕的笔记本电脑。
laptop resetting during install
can anyone help my laptop keeps switching itself off and restarting during restore even if i use a stand alone windows not restore i have even tried from usb stick windows 7 BUT if iinstall linux or hackintosh its fine installs ok just i even have replaced the hard drive twice does it on windows any ideas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
i think you forgot boot disk uttulities run over it
由完成的
添加一条评论
5个答案
Hello richardapayne
Sounds like a driver, a memory problem (not to sure why other OS's work though)
Does it restart at the same spot during the installation? If yes what is the installation doing at this time?
I would try running memtest86 for at lease 5 passes (I leave it run all night.)
http://www.memtest86.com/
When in Lunix run psensor to check your CPU temps. When installing Windows the CPU can max out and if the CPU gets to hot the computer will reset or turn off.
http://wpitchoune.net/blog/psensor/
这个答案有帮助吗?
得分 0
添加一条评论
My aspire 8920g restarting with power is on.
In the mode safe works ok.
这个答案有帮助吗?
得分 0
1条评论:
I had the same problem and after a bit of research I found out that disabling the two cpu cores in the device manager in safe mode solves the problem. Here's the link to the source: How to fix a notebook that freezes when plugged to AC power?
由完成的
添加一条评论
that common in 2008 models. try to update bios. https://www.acer.com/ac/es/ES/content/su...
这个答案有帮助吗?
得分 0
添加一条评论
The answer to this Reboot problem is the Capacitor located right under the CPU. Setting the CPU to use only a single core cpnfirms this is correct. There is a repair video on youtube that shows how to do this. The Original capacitor (Single Unit) is peeled off the board and replaced with 4 x 330uf - 2.5v Tantalum capacitors in its place.
It takes patience and care to complete, but is NOT too hard for most enthusiasts.
Whats needed: 2R5TPE330M9 330E 330 330UF 2.5V D SMD tantalum capacitors
这个答案有帮助吗?
得分 0
添加一条评论
i have the same problem while trying to reinstall windows vista home premium because they got corrupted during a windows 10 installation and trying to boot results to a restart
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
richardapayne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 2,608
