跳转到主内容
The sixth generation Grand Prix, a front-engine, front-wheel drive vehicle manufactured by Pontiac, a division of GM. Sold in both coupe and sedan configurations.
39 个问题 查看全部
Wiring diagram 2000 grand prix
I need pcm wiring diagram for 2000 grand prix 3.8 supercharged
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Alternator will not charge bat. Alt. good per 2 off car bench test, fusible link is good, charging system fuses are good. Thanks
完成的
添加一条评论
2个答案
最有帮助的答案
Lewis colbert, take a look at the images. There is a lot that works with the PCM. It might be easier if you tell us what the issues are.
这个答案有帮助吗?
得分 4
2条评论:
I don't really have a problem I'm installing this motor in a 65 G10 and want to make sure it's all conected right
完成的
First I'd like to say sorry for not thanking you oldturky03 and I can't read these on my tablet is there a way I could get a PDF of this? And do you have the rest of the wiring diagrams? Thank you so very much for the fast reply your very kind.
完成的
添加一条评论
I have a 02 Grand Prix se 3.1 and lost spark out of the coil packs.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lewis colbert 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 140
总计 14,196
