跳转到主内容
加入维修社区 - 创建账户
Sony Xperia J 是一款运行 Android 系统的智能手机。
Problem with network signal
I have a problem with my network signal.
I opened phone and found out that the connector from the second (lower) board has broke.
By the connector i mean the one that has a screw hole in it, its by the vibration mechanism.
picture of the board
So i would like to know if that's why i don't get network signal, or should i investigate more?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
Do you mean this connector?
If this connector is broken you may have a problem with network signal strength. You need to solder it or replace this subboard. A good idea is the replecement of the rf cable (a black cable connected to this subboard).
这个答案有帮助吗?
得分 0
添加一条评论
The problem that you state.have different problem with mine situation
这个答案有帮助吗?
得分 0
添加一条评论
It seems that the RF connector is damaged...kindly look at the condition maybe that is the reason and you need to replace.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
filerzr 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 23
总计 3,189
