跳转到主内容
The Audi A6 is an executive car made by the German automaker Audi AG, now in its fourth generation. All generations of the A6 have offered either front-wheel drive or Torsen-based four-wheel drive – marketed by Audi as their quattro system.
30 个问题 查看全部
Alternator or Voltage Regulator? Burned two batteries in a week.
The 1996 Audi A6 Quattro cars battery gauge will jump up under acceleration but doesn't seem to hold charge even after long periods at high R P Ms dies at idle I had it tested at AutoZone they stated must be Alternator but the Voltage regulator much cheaper part and a fix I could manage, the alternator not so much . Any information as how to diagnose one from the other would be greatfully welcome.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You can test you alternator with a voltage meter . With the motor off get a reading it should be around12.6v then with the motor running it should be 14.2v but if its over 14.6v you have a issue with regulator. If you've burned out 2 batteries in a week your looking at the voltage regulator but most regulators are inside the alternator. If moneys an issue try an auto wreckers . Cheap place for parts and your dealing with an old car so why not put an old part on . Probably last as long as the car and if it doesn't you can get 3 or 4 alt at a wreckers for the price of a new one. One of them is bound to outlast the car.
https://www.youtube.com/watch?v=LGB6ZEjG...
this is a good video to show you proper test
这个答案有帮助吗?
得分 3
添加一条评论
Keith, this should explain how to check Alternator vs. Regulator.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Keith 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 6
总计 3,263
