跳转到主内容
加入维修社区 - 创建账户
GoPro HERO3 于 2012 年 11 月发布,是一款支持 Wi-Fi 功能、4K 分辨率的数码摄像机。
My GoPro got wet
Hi. I was surfing and after a wipeout my GoPro case got broken and consequently my GoPro Hero 3 got wet (salt water).
I tried to let it dry but after this incident, the camera doesn't turn on anymore and now only blink a red light on the back of the camera.
Nothing else happens.
When I let it charging for around 30 minutes, the GoPro display shows "GoPro" but nothing else happens.
Do you guys think that could it be a solution for that? I really don't know if it is, but.. well.. let's try to ask ;)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I'm experiencing the same issue. But, I did NOT wipe out and I have been incredibly careful with the housing and camera. The is the second GoPro to have issues. I think it's time to give up!!
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
So the bad news is salt water is electronics' worst enemy. With that being said, the device still shows sign of life which is good. What you can do is follow the ifixit teardown guide to take out the logic board. After you take it out put it in something that has greater than 70% alcohol and scrub it with a toothbrush. dry it with a hair dryer or just leaving it out to dry for a few hours and try to reassemble it. If the water damage was minor, it should work.
GoPro Hero3 拆解
这个答案有帮助吗?
得分 1
1条评论:
Thank you so much I don’t know what I would have done without this
完成的
添加一条评论
添加你的答案
ra7osurf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,645
