跳转到主内容
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
74 个问题 查看全部
Fuel level gauge mechanism and repair
I want to learn how Toyota corolla Altis 2008 Model fuel level gauge works and repair it if needed to.
I also want to see how to adjust the Gauge that shows wrong level in the tank.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Boon, the fuel gauge sending unit is located on the fuel pump in the fuel tank of the car. It consists of a float, connected to a thin, metal rod. The end of the rod is mounted to a variable resistor. Take a look on here about how it works. they are really not that adjustable unless you bend the small metal arm. This will no be very exact. I'd have someone measure the resistance of the unit to see what the values are. The only other thing would be to replace the sending unit.
这个答案有帮助吗?
得分 4
1条评论:
Thank you so much for your valuable information and time given .. it was a quick answer too, to my question !
完成的
添加一条评论
Toyota 2003 allion not working fuel meter wirang problem .and fuel pump motor full replas .Desborad meter replies but not working please help me
这个答案有帮助吗?
得分 0
2条评论:
Im new compelat fuel pump motor full replas .but Desborad fual meter not sho
完成的
Thanks but im new Desborad meter compelat replies but Desborad fual meter not sho andno reding is big poblon please solutions help me
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Boon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 77
总计 17,261
