跳转到主内容
加入维修社区 - 创建账户
Version 2 of Parrot's toy quadcopter with HD camera, controlled over Wifi by smartphone.
My drone does not take off.
my drone does not take off after replacing the central cross section. I think the blades are spinning the wrong direction.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
I found elsewhere that I should use the reset button on the bottom of drone, however my reset button doesn't seem to be working and I think this may have been damaged during crash. would like other suggestions or a how to on replacing the reset button. Do I need a whole new board or can the reset button be replaced independantly?
完成的
添加一条评论
2个答案
最有帮助的答案
Is there any software for this for pc? As my blade qx3 has, and you can fire up each motor separately and shows on the screen which way they should rotate.
Top left and bottom right rotors should rotate the same. And top right bottom left should rotate the same to each other, but opposite to the other pair.
这个答案有帮助吗?
得分 1
2条评论:
My drone is going to one side
完成的
Mine is doing the same
完成的
添加一条评论
Yes, have you changed the blades? If so, make sure the blades are on correctly. What I mean is that a blades at on the a motor, while c, for counterclockwise blades are on the c motor. Search up propeller replacement on Google
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
robredanz 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 10
总计 2,652
