跳转到主内容
许多佳能数码相机和胶片相机的修理和拆卸指南。
1795 个问题 查看全部
trouble massage like Ubdate Firmware *Bios Mode*
my printer write a massage when i want to print an on the printer the massage says
Ubdate Firmware
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
Canon ImageRUNNER 2422 2420
回答此问题 我也有这个问题
这是一个好问题吗?
得分 51
2条评论
Have u solved it? I have the same problem. Thanks
完成的
plz help i need a help
完成的
添加一条评论
15个答案
最有帮助的答案
ok then how can I solve this problem plse help how can I do " Ubdate Firmware
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
Canon ImageRUNNER 2422 2420"
这个答案有帮助吗?
得分 20
2条评论:
完成的
canon ir 2420 update firmware bios mode
完成的
添加一条评论
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
这个答案有帮助吗?
得分 6
添加一条评论
this is all problem solution
这个答案有帮助吗?
得分 3
1条评论:
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
完成的
添加一条评论
这个答案有帮助吗?
得分 3
添加一条评论
hello i have machine canon ir 2420 , error message update firmware , i am change board usb , fix problem
这个答案有帮助吗?
得分 2
1条评论:
That will work for sure! BUT will cost you a fortune! And yeah - that is much easier!
完成的
添加一条评论
https://www.canon.fr/for_work/mobile-sca...
这个答案有帮助吗?
得分 1
添加一条评论
Here is what you can do. That helped me once.
You need to get to mainboard and find there flash memory. In my case it was chip - 25Q64BVFIG. It contains firmware for that machine.
Then - need to desolder it, reprogram using programmer with support of that type of schemes and solder it to mainboard again.
Downbelow will be a link for dump to download (must mind you - that Canon iR-2420 was in Russia and I'm not sure about differences between US/Canada and European firmwares. Just to let you know that beforehand - that there might be some problems to show up. But I suppose - since machine will finish loading inner software and comes to ready state - you can just figure it out by playing with local/country settings). These are photos before and after (connector melts a little)
- About dump - it's ready to use with your programmer - it's been taken from newly installed machine (not by me - but from guys from similar Russian tech forum). DUMP for reflash memory chip
- About programmer - mine is - TL866A - pretty simple and cheap
Good luck! Hope that will works for you!
这个答案有帮助吗?
得分 1
1条评论:
Here is link to forum Copytechnet - where I originally posted this recommendation
http://www.copytechnet.com/forums/canon/...
完成的
添加一条评论
yep! what if i swap the chip with the one from 2318 ? will it work?
这个答案有帮助吗?
得分 1
1条评论:
Not 100% sure, but suppose yeah, that might work for you.
完成的
添加一条评论
ما حال مشكلة هدا راسالة الة سحب
canon 2420
Message please wait
这个答案有帮助吗?
得分 1
添加一条评论
this is also my problem pleas give me solution
这个答案有帮助吗?
得分 0
添加一条评论
what would be the problem of this and what should i do ?
这个答案有帮助吗?
得分 0
1条评论:
what would the problem of this and what should i do
完成的
添加一条评论
Boa tarde a equipe da CANON, eu tenho uma maquina fotocopiadora canon 2420, ela tinha problema de fonte e ja foi resolvido, so que nao esta a fazer copia, aparece na tela a seguinte mensagem: Update Firmware * Bios Mode* 2010/10/28 VO.10W STARDR 5N
这个答案有帮助吗?
得分 0
1条评论:
Como solucionar esse problema?
完成的
添加一条评论
Please if any body knows the solution on how to fix this problem of (* bios mode * firm ware update ) on IR2420 Canon .
Please E mail me on vifeanacho@gmail.com
这个答案有帮助吗?
得分 0
添加一条评论
i need ir 2420 firmware
help me
这个答案有帮助吗?
得分 0
添加一条评论
https://cloud.mail.ru/public/E3FN/g9Ry4q...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wendosen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 39
总计 8,858
