跳转到主内容
加入维修社区 - 创建账户
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
MacBook can't charge battery but It powers on
Hi,
Probably my a1184 power adapter has broken my macbook unibody a1278, since when I connect it to the magsafe, no led light on the connector (neither green or ambra) but It powers on (if the battery has charge) and, with the power adapter connected, It works from the wall energy but It doesn't charge the battery (in fact macbook show "not charging" message).
A technician (Apple Premium Reseller) told me that I've to replace my Logic Board (480 € of charge) but Can It be instead the DC IN card (that costs lower... sorry but I don't trust him)?
Thanks a lot
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I don't trust him either!
完成的
添加一条评论
2个答案
已选择的解决方案
First try removing the battery and see if it starts. It should. We need to try to isolate the problem and if it boots is probably not a logic board problem. We might need to try several things. I have not seen a AC adapter that I didn't get some kind of light with. Download Coconut battery to test the battery out. http://www.coconut-flavour.com/coconutba...
Try starting with just the battery. This seems to be a power issue to me. So we check the AC, mag port, battery and battery connector. Let us know the results of the above and we'll proceed. Thanks. Interesting problem.
这个答案有帮助吗?
得分 3
3条评论:
Thanks for your answer.
I've tried another battery and another magsafe adapter with no success.
Macbook without battery and with Magsafe connected doesn't power on...
Macbook with owns battery (or another one) boots succesfully but when I connect the magsafe, no charge occurr...
I've already tried SMC and PRAM reset...
完成的
After re-reading a couple of times I see it's the magsafe board. All the tests point to it. Here's how to replace it: MacBook Unibody Model A1278 DC-In Board Replacement
完成的
Good follow thru +
完成的
添加一条评论
Hi, I have a same problem above for Macbook White A1181. Please suggest me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Riccardo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 5,692
