跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
问题已关闭
Componenet Identification on A1278 logic board
Could someone help me identify this component. It has not affected the useability of my laptop, but did cause the laptop to shut down and a puff of smoke came out and then it rebooted back up and has worked for weeks. But would like to fix it before stops working
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
If its not broke why fix it? You say its functioning right?
完成的
添加一条评论
2个答案
已选择的解决方案
Chris Nyberg, that is reference designator C6603 which is a 100uF 6.3V 20% tantalum capacitor in a AL1 case. It is part of the speaker amp circuitry.
这个答案有帮助吗?
得分 2
9条评论:
Awesome. Thank you.
完成的
So is there a picture of the logic board out there that shows the area of the components? Or how do you go thru the schematic and actually find that component? Is the designator actually shown somewhere on the board or do you have a actual picture is what it comes down to?
完成的
Board views show the components' placement and their names. Once you put a name/designation on your component, you find the details about it in the schematic .
完成的
What board views? Is it software or a website?
完成的
It is software. Google for the schematic by your logic boards 820-XXXX number. then check to make sure that the seller offers the boardview with it.
完成的
显示更多的4条评论
添加一条评论
Tell us model number of this so we can help you better.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 922
