whered is the idle air control valve located
where is the idle air control valve located
deborahfoley70, you did not tell us what engine your Honda has. The Idle Air Control (IAC) is marked on the images posted.
Location on the 4cylinder engine is center rear
Location on the 6cylinder engine is left side of the engine
这个答案有帮助吗?
This is always located just aft of the throttle body intake. It will usually have a 2 wire cable going to it. This valve keeps the engine from stalling when the main throttle butterfly is closed.
这个答案有帮助吗?
Mounted underneath throttlebody with 2 Phillips head screws that be difficult to remove on high mileage vehicles
这个答案有帮助吗?
过去 24 小时: 8
过去 7 天: 31
过去 30 天: 136
总计 36,933
1条评论
Can tell me where it is located
由 vjohnson1165 完成的
