跳转到主内容
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
missing zif socket where can I get a replacement?
I need a zif socket for my ipad mini a1432 power/volume flex cable where can I get replacement
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
try to search for dbxstore
完成的
添加一条评论
1个答案
已选择的解决方案
russellrobinson2, the connector is a FF18-6A-R11AD-B-3H. It is available at places like this and many others.
这个答案有帮助吗?
得分 1
6条评论:
Can you give me any others that are not manufacturers...
完成的
I don' t quite follow you on that.
完成的
I tried to do a google search the connector ff18-6a-r11ad-b-3h and the only thing that comes up is a manufacturing company called electro shield also they had a minimum order of a 100 and I only need one connector besides to make an order I would need a PO number...so I was wondering do you know any other places I could purchase the connector I need because Google search is not giving me any other sites
完成的
Just went to that site and changed quantity to 1. It did let me go ahead and place an order. Bad thing is $15 shipping charges. Go ahead and try it if that is what you need to do to get the connector, see what happens. I also put in a request at http://www.galco.com/ where those are in stock as well. I'll let you know once I find out
完成的
I found some on eBay for 8.99 @ xcentrikgroup(10615)
完成的
显示更多的1条评论
添加一条评论
添加你的答案
russellrobinson2 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 210
