跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
How to avoid losing screen sensitivity after OCA glass replacement?
Hi,
I've started changing the iPhone 6 glass using different equipment (we remove and replace the polarizer too).
We are using OCA glue and an autoclave for this activity.
How can we avoid losing sensitivity on the touch screen?
The screen definitely loses sensitivity after the replacement.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
Does your screen look like there is static? Or does the screen look perfect other than touch sensitivity?
完成的
it won't be hundred percent because sometimes it has horizontal lines across the screen and sometimes static
完成的
添加一条评论
15个答案
已选择的解决方案
Have you tested using less glue?
EDIT: following Ged's comment, let me rephrase, and please note that I have no practical experience with refurbishing. I'm just familiar with the physics of it:
Have you tested with thinner sheets, or if there is no such thing, can you use LOCA and try varying amounts and test?
Or just do multiple tests while changing 1 variable at a time: the glue thickness or quality, curing time, etc.
It seems from the people doing it this side of the world, that better results are obtained with LOCA anyhow. Some opt for OCA because it seems more controllable and less messy, etc. but they're not very happy with the results.
这个答案有帮助吗?
得分 3
2条评论:
It's actually the non original polarizer and the non use of the "conductive glue" one dot each side overlaping the polarizer and the OCA. Plus you can not remove the polarizer and install a new one without vacuum laminating it on the i6. The rooler will not do. If you don't have a vacuum laminator a plastic razor blade is your best bet but still will give you problems. Think about it? If the polarizer is not "laminated" "hard" to the LCD properly are you going to have poor touch? If you do not have a vacuum laminator then never remove the polarizer
完成的
If there is any gap between any layer there would be a bubble.
完成的
添加一条评论
Can be that you dont add the anti-static silver conductive paste (the thin silver line at the top) it can cause issues.
这个答案有帮助吗?
得分 1
2条评论:
Do you have a picture of that? Interested to know what you're talking about.
完成的
https://www.youtube.com/watch?v=pBppa-D_...
Would assume its the same on iphone 6
完成的
添加一条评论
If your screen looks like it has static use the paste http://stsparts.us/products/conductive-p...
How are you cleaning your polarizer glue? Make sure the lcd is completely clean before new polarizer application. Another common mistake is to damage the flex on top. Make sure to take polarizer off from top to bottom
这个答案有帮助吗?
得分 1
添加一条评论
I've started adding a product called "conductive paste", applied on the top edge of the screen. Issue solved!
这个答案有帮助吗?
得分 1
添加一条评论
I would say this is something to do with the OCA. I've bought polarizers before and they're never quite just right, some are way too light. I'd ask some suppliers if it would be possible to buy 1 sheet of what they use as a sample. @Rany, I don't think you have to remove the backlight when using OCA because of how controlled it is. I assume OP uses a machine to automatically slice the polarizer off and then a vacuum laminator to reapply it, either way there's still no need for any liquids to go near the backlight of the LCD.
这个答案有帮助吗?
得分 0
添加一条评论
I faced the same problem that you faced it's not about static issues but it's about lcd thickness and glass and OCA the real problem is before we remove glass it's working fine right! also after applying Polarizer it's fine ! also but the problem appear with the two following steps after Vacuum Laminating Machine and After Autoclave most of them after Autoclave for iPhone 6 and 6 Plus I did about 40 - 50 LCD's all same issue so there must be something wrong !!! I found the problem but don't know how to fix it the problem is again it's about the lcd and touch contains from layers vertical and horizontal not visible for human eye so after the pressure the edges of the lcd under the glass it curve so the touch will not be responsive for sure ! but you can still get touch sensitivity if you press hard on glass it will respond so please if any one got an idea how to fix share us please we paid large amount of money and of course we don't want to lose our friends and customers I used anti static pen same problem I used LOCA no problem !!! 100 % working so please we need a solution for OCA iPhone 6 and 6 Plus LCD's
thanks a lot
这个答案有帮助吗?
得分 0
6条评论:
I agree with all that is said here. Exactly same issue. Not static issue and I find it onlywith iPhone 6, 6+. But when i don't damage the polarizer everything works perfect. Only happens when I have to change the polarizer. Still waiting for a solution on this. I don't thing it's the oca or the glass size since I use same material on the lcd that don't need oca replacement and they work fine. Might be some issue with the application of polarizer. Any help will be appreciated
完成的
The problem is with copy polarizer but unfortunately there's no way to test original polarizer... How did I get this answer? Well I removed old glass without removing original Polarizer and I removed in purpose the static paste also didn't use!!! I applied oca and glass and perfect working like as it was so as a conclusion with iPhone 6&6+ no copy only original will work perfectly but the very important question is how to test OCA & Polarizer if they are original or copy??? Before buying them or just testing them before applying them anyone knows how to test good polarizer????
Thanks
完成的
I agree it's non original polarizer. I found a listing for sale when surching for polarizes that said "these are aftermarket polarizers" we also have original "that have better touch response" for sale in another listing for a higher price. So they seem to know this is a problem.
完成的
Agree too. I had mentioned before that is was due to the static paste. But now after reading this I realized that I also ordered OEM polarizers and OCA sticker. My provider is very trustworthy when they claim parts are Original. So now I don't have issue with the touch.
完成的
Update I got original polarizers from China and they cost twice as much but now have no problem using the one dot method "conductive glue" it's funny every video on youtube excludes this "real world step" ? Why?
完成的
显示更多的1条评论
添加一条评论
Have you tried lowering the mpa on the laminating machine ?
这个答案有帮助吗?
得分 0
1条评论:
No. Have not messed with setting. Can you be more detailed as to witch setting to adjust the mpa. Any advice will help
完成的
添加一条评论
After many test and fails right now all is working fine after I am using oem "mitsubishi" oca sticker. Also adding conductive paste on all screens. And I have not had that issue anymore
这个答案有帮助吗?
得分 0
添加一条评论
I'm getting bubbles under the polarizer film after using the built in pump laminator. It was working fine go awhile then all of a sudden I'm getting bubbles in the Same place. Anyone have the same issues?
这个答案有帮助吗?
得分 0
添加一条评论
Hello, this post will help you a lot: How to solve iPhone 6 Touch Screen Problem
这个答案有帮助吗?
得分 0
添加一条评论
the problem is about polarizer and oca they should be original otherwise you will have problems I'm working on LCD repair for 9 months and this is the problem moreover if they are high quality you will face bubbles problem
Hope this will help.
这个答案有帮助吗?
得分 0
添加一条评论
OFF THIS TOPIC.
Been doing great on screen refurbishing but seems like on the iPhone 6S once i place on "KO" lamination machine - the screen has lots of Big bubbles. I have done thousand of iphone 6 & 6 Plus but i can't get it right on the 6S. Any suggestions on this? Thank you
这个答案有帮助吗?
得分 0
1条评论:
You can also buy front glass with frame, oca and polarizer, you don't need anymore laminating the oca and polarizer on the glass. you can work faster and there's no dust and hairs on the oca when you don't have a free dust room.
完成的
添加一条评论
I have the same problem. Please check this video: https://www.youtube.com/watch?v=DVMsZH0D...
At the top of screen is oca for iphone 6 and bottom of the screen is oca for iPhone 5. Do you have any experience with defective oca glue ? Unfortunately I don't have another pack of oca for iphone 6 so I can't test it. Is the oca for iPhone 6 defective ?
这个答案有帮助吗?
得分 0
添加一条评论
Hi, I have a similar issue and I hope someone can enlighten me on this matter.
https://youtu.be/GuPwaGTbS3s
So basically my problem is that when I need to remove and replace the polarizer film on the iPhone 6 (mainly), the screen starts to get purple when and where you touch it... I use copy polarizer films, but I do add the silver conductive paste at the top (I also use OCA and 5 in 1 vauum laminator machine). The problem appears once every 5 to 10 screens maybe, but it is very annoying and no matter how many times I redo the acreen I can't seem to find a way to get rid of it. Any suggestions, is it poor quality polarizer film or something else? Thanks
这个答案有帮助吗?
得分 0
添加一条评论
I've the same issue, but i can't solve the problem.
I think it's the copy polarizer, but i don't know where i can buy good quality polarizers.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rgrimoldi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 12
总计 7,714
