跳转到主内容
加入维修社区 - 创建账户
The Sega CD I, A.K.A. The Mega CD I (in Japan) was the original Sega CD unit released in 1991.
My Mega CD1 won't read Game CD, but can play audio CD.
Hello. My Mega CD1 won't read Game CD but audio CD play without problem.
The CD-ROM icon never appaeared in the menu.
Is this an optic problem and supposed to be tuned or is there problem in other parts?
Thank you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
adityarai2001, sounds like an issue with the laser. I would try to clean the laser with a professional clean kit first. You can also disassemble it by using these guides and clean it. If that does not work you most likely will have to try to replace the laser assembly.
这个答案有帮助吗?
得分 1
添加一条评论
If you have a multimeter check the ohms of the laser should be at 700 ohms or .700 k ohms make sure not to adjust the Focus pots
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
adityarai2001 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,122
