The spinning cycle always fails
The machine washes and drains but every time it starts the spinning cycle, starts speeding up, and then it stops and shows UL on the display.
The unit is leveled and we have tried doing it empty and still fails.
Claus Rieper, as you already know the UL error is an unbalanced load error. Since it happens even with an empty washer it sounds like the problem is the rotor positioning sensor (RPS). This is the part you would need. Here is a video that at 3:09 shows the location of the RPS. Hope this helps, good luck.
这个答案有帮助吗?
Mine does the same thing but spins every time it's supposed to except the very least spin at about 6 min left on the clock then it will start running water again like it's rinsing, it's the very last spin the ul code pops up
This is exactly what mine does. Biggest hunk of junk
I think this is the problem we’re having. But not exactly sure. The video was great, but don’t know what to do next to be sure if I’m getting the right part for the problem.
@Kris Reschke when does it happen? All the time, regardless of load size and even when you have the load balanced? How old is your washer? What is the exact model for your washer?
While trying to get to the positioning sensor as advised by oldturkey03; I noticed that the bolt that holds the rotor in place was totally loose, tight it up, gave it a try and now the washer is working OK
Thanks for pointing me in the right direction and video.
这个答案有帮助吗?
I see answers for this problem.. it states to get a part for a whirlpool washer however I have a maytag bravo. How do I know if that will work or where do I get the part. I tried the tightening of the screw at the bottom of the washer. That did not solve any problems. Please help
My maytag bravos kept having a uL warning. And it was because the tub bearings and shaft were worn , thing sounded like a freight train when spinning. It would get down to 006 on time and set a uL reading and start all over . I replaced tub shaft and bearings I bought on line and solved the problem.
Loose bolt was spot on! Thanks for the help!
My Bravos XL had ul code coming up with light and no clothes. I flipped it and checked the Allen key bolt and it was tight. I noticed it was very dirty under and on the bottom of the washer. I loosened the bolt and took the flywheel? off. I cleaned it all up with wd40 and paper towels, put it back together and it now works fine. Thanks for the info provided
这个答案有帮助吗?
Mine is dirty too, but there was a puddle of water as well. I didn't check the bolt, and already took the flywheel off. So the seals are bad. Is it dirty because the flywheel has been rubbing on the rotor as well as getting wet? I don't want to tear it all down to the bearings, but it sounds like I'm going to have to, am I right?
过去 24 小时: 5
过去 7 天: 59
过去 30 天: 270
总计 28,856
