跳转到主内容
加入维修社区 - 创建账户
通用电气 (GE) 冰箱的维修指南、故障排除信息及服务帮助。
Why won't my icemaker dump ice?
I have a GE Side by Side Refrigerator Model GSH23JSXLSS.
My icemaker will not dump the ice. I just replaced the icemaker with a new one. It is getting the water and it freezes but will not dump the ice. I also changed the water filter. The water despenser works great and water is getting to the icemaker too. I can initiate the dump sequence and it will process the ice out but it will not do it automatically. There is nothing abstructing the flow of water or the arm that stops the cycle. Had the same problem with the old one that I just removed.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
I change brand new ice maker and still wont dump ice
完成的
Didn't you read my answer?
完成的
ummm I have the same problem 21 year old GE (WR30X0327) not dumping ice. If I buy a NEW ice maker, I assume it comes w/a NEW dispenser control board and dispenser switch????
完成的
添加一条评论
1个答案
已选择的解决方案
Cause 1
Dispenser Control Board
The dispenser control board governs most of the functions of the dispenser system. If only one dispenser part is not working, it is probable that an individual part has failed. In this case, test each of the dispenser components before testing the control board. If the entire dispenser system is not working, the control board is more likely to be at fault.
Cause 2
Dispenser Switch
The dispenser switches send voltage to the dispenser. If one of the dispenser switches is defective, the dispenser will not work. To determine if a dispenser switch is defective, use a multimeter to test each switch for continuity. If a dispenser switch does not have continuity, replace it.
这个答案有帮助吗?
得分 3
10条评论:
Where is the dispenser switch located?
完成的
@icemakerreplace what's your specific model # ?
完成的
Where is the dispenser switch located on Samsung model # RS261MDBP
完成的
Where is the ice makers dispenser located at and how do you get the water to make the ice?
完成的
显示更多的5条评论
添加一条评论
添加你的答案
Willie Jacobs 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 19
总计 13,719
