跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
How to locate power pads on A1398
mac book pro will not power up via keyboard. Are there any power pads on this model rather than having to short out the #5 and #29 on the keyboard ribbon, I am finding it almost impossible to do on the ribbon because it is so small. I'm not entirely sure if it should be the 5th from the left or the right (I have my mac back off and I see the fans at bottom and the batteries at the top.) How many pins should I see ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
audreyc79, even this board has power on pads. They are used for debugging the hardware, not for routine power-on purpose of course. Just apply a jumper across the pads for a brief time.
这个答案有帮助吗?
得分 2
1条评论:
not on this A1398
完成的
添加一条评论
power pads on this are your CHARGER, this is supposed to automatically turn on when you plug your charger in.
这个答案有帮助吗?
得分 0
1条评论:
True That!!!!!!!!
完成的
添加一条评论
My a1398 dont have this power pads.. How can I locate?
这个答案有帮助吗?
得分 0
添加一条评论
A1398, Mid-2015 power pads location:
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
audreyc79 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 21
总计 3,118
