跳转到主内容
加入维修社区 - 创建账户
Released July 2012 by Fuhu, Inc. Model Number: NABI2-NV7A.
tablet speakers do not work anymore; only with headphones
my daughters tablet is not even a year old, and last week the speakers stopped working. the sound works with the headphones, but not with out! And when i tried to get customer service the hold time was over an hour, and the online ask a question wouldn't let me ask my question! Also, when registering her tablet, not all of the tabs were working so i was unable to finish that process as well! HELP!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 21
7条评论
I bought two of these tablets, brand new; one in December 2014 and one in February 2015 for my two sons. In March 2015, the speakers on the first tablet stopped working. Two months later the same thing happened with the second one. This must be some sort of design flaw. I liked the tablets before this, but ran into the same problem with customer service hold times, and I also could not find the receipt for the first one, so they would not help. I ended up buying a Kurio tablet a year ago and have not had any trouble.
完成的
I have the same issue with my Pro 12 tablet no sound coming out the speakers, works well with headphones only. How can i fix it? Is there an app to download?
完成的
My daughters highq learning tab will only work with head phones otherwise no sound !?
完成的
Today my sound went out and it don't work with headphones
完成的
@Sabrina Evans how can I fix my tablet?
完成的
显示更多的2条评论
添加一条评论
9个答案
已选择的解决方案
amg112586, it is possible that your headphone jack is stuck. That way your tablet would have opened the speaker circuitry and only work with headphones. I would try to install and remove a headphone connector in rapid sequence in to the jack. Also, a few drops of high grade isopropyl alcohol might help loosen it up. Should that not work you must consider replacing the headphone jack and/or the speaker
这个答案有帮助吗?
得分 14
7条评论:
A drop of contact cleaner will work even better.
Note, WD-40 is not a contact cleaner ;)
完成的
It doesn't work for the past few weeks what should I do
完成的
reneproulx7 what have you tried? The Nabi's do have trouble with bad speakers etc.
完成的
No good, you can see the headphone icon turning on and off so it knows that the headphones are unplugged!!!
完成的
Thank you, doing both worked. And another thanks for the WD-40 note. That would have been my first go to! In and out worked, then to be safe, high grade isopropyl alcohol.
完成的
显示更多的2条评论
添加一条评论
This is c a common problem with the nabis. My son's done it as well. I downloaded soundabout app and they work now. The app has a free trial to see if it works then to get it, it was $2.99. Hope this helps.
这个答案有帮助吗?
得分 5
2条评论:
I downloaded the soundabout app but it still isnt working how do I turn it on to activate the speakerphone I have a nabi 2
完成的
Sound Was ok a few minuits ago
完成的
添加一条评论
Mabye replacing the earphone jack
这个答案有帮助吗?
得分 2
2条评论:
You need to explain how too do it!
完成的
添加一条评论
The dream tab speakers are not working show me and do it automatically
这个答案有帮助吗?
得分 1
2条评论:
@reneproulx7
I had the same issue with my son's dreamtab. Both speakers was not working but the headphones did. I took the dreamtab apart and I unplugged both speakers and headphone jack than plugged them back in. I decided to test it out while the tablet was still open and everything seemed to be in good working order. I also made sure to check the tablet was up to date with the latest updates. This can be done by switching to parent mode and going into the settings. This fixed our problems, maybe could work for you also. If you need help on how to open the dreamtab, just look for a good youtube video.
完成的
My speakers on galaxy 3 tablet isn't working either, and I can't hear a video to watch it ...please help
完成的
添加一条评论
You could shut your technologies down and wait about ten minutes and see if the volume works and of it doesn't work comment on this
这个答案有帮助吗?
得分 0
添加一条评论
Suck the area of the speakers.
Read this youtube comment and it actually worked.
这个答案有帮助吗?
得分 0
添加一条评论
Hi !
Check the harware. I had the same issue with a Chuwi Hi8. the Speaker wire was cute close to the weld. I welded again then it work. Wires are very tiny and fragile.
这个答案有帮助吗?
得分 0
添加一条评论
Try soundabout. Got my son speaker to work with it
这个答案有帮助吗?
得分 0
添加一条评论
Victoria🌈 that’s trying to find her headphone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
amg112586 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 48
总计 79,957
