跳转到主内容
The Samsung HLM or HLN series is a line of projection televisions.
29 个问题 查看全部
My picture is very dark
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Serial # B19G3CKL501709L
MODEL # HLS5087WX/XAA
完成的
添加一条评论
3个答案
最有帮助的答案
hpimidwest, it is possible that it is your bulb.It could mean that your lamp is old (4000-5000hrs) but it could also be your ballast. As the lamp gets older, it requires more voltage to spark or ignite. If you still have a picture, just dark/darker you are a bit in a catch 22 situation. You can buy a new bulb and hopefully that will resolve the issue, but if it does not, you would have to replace the ballast. You may end up purchasing both. There are numerous variation of ballast and bulbs. We'd need the exact model number to help you out further.
这个答案有帮助吗?
得分 3
1条评论:
my tv is okay, after a little while, its getting dark, and nothing at all...it has sounds, what is the problem? thanks
完成的
添加一条评论
One of the bulb needs replacement if not calibration. If you are able to take apart, you can test which one is out. If you can't take apart and it's under warranty, get it replaced for free.
Good luck.
这个答案有帮助吗?
得分 1
1条评论:
what bulbs are you talking about
完成的
添加一条评论
no picture has sound wont stay on
这个答案有帮助吗?
得分 0
1条评论:
drahming 415 you posted a question as an answer to a different question. Your question can now be found here want say on,no picture,has sound
完成的
添加一条评论
添加你的答案
hpimidwest 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,724
