跳转到主内容
Eighth generation of the Honda Civic.
58 个问题 查看全部
How to replace hybrid battery on a budget?
My 2006 Honda Civic Hybrid (no-navi) has about 260k miles. It has the original hybrid battery and it is definitely not holding charge. I like to tinker and was hoping someone out there had some information on how to replace it with an aftermarket or how to rebuild the battery pack. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
Thank you for all the info. Yes, the car has two batteries -one for the typical accessories and starter (12V) and the hybrid battery that powers the hybrid motor. FYI: the hybrid battery charges the 12V battery! I have use the links provided above and have found other similar links as well. They all pretty much do the same, take the sticks out, recondition them using an off-the-shelf R/C (remote control) discharge/charger. I will get to it! Fun stuff. Have a good one everyone!
完成的
添加一条评论
1个答案
最有帮助的答案
wilmer, take a look on here http://www.homepower.com/articles/vehicl... Looks pretty involved but could safe you a couple of bucks:-)
这个答案有帮助吗?
得分 1
5条评论:
Thank you for informing me but it's already to late to fix it :)
完成的
Also, oldturkey03, why isn't my rep going up when my answer is accepted or voted up. It goes down when it's voted down. Look at my activity: https://www.ifixit.com/User/Activity/455...
完成的
Apple, it is possible that you have surpassed the maximum of daily points. Right now you show 665 reputation points. I shall check in the morning and see what it does. If there is no change I will contact the ifixit gurus for you
完成的
Thank you oldturkey03. It looks like it's getting a bit better but the other answers that got accepted aren't giving me reps yet.
完成的
That is correct. Any point you receive above your daily limit will not get counted.
完成的
添加一条评论
添加你的答案
wilmer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 12,551
