跳转到主内容
加入维修社区 - 创建账户
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
Power button not working.
Hi, my girls phone recently started doing this weird thing where it appears that the power button is being pressed down even though the button isn't being press or stuck in the pressed position. I order a replacement part, the daughter board that has the power button on it and after I did it appeared to be working correctly. Then about a day or so later the power button stopped working all together. Not sure what the issue might be other than a bad part but I find it strange that it was working and then just went out all together.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
1条评论
Same thing happened to me but it started after a phone call right after I got off of the phone I was going to try wiping it completely to see if that works it definitely has to be something in the programming because the phone didn't get damaged
由完成的 分享
添加一条评论
5个答案
最有帮助的答案
Get cocoa butter or like kind of a grease on your fingers and attempt to access apps and do regular things on your phone and it'll stop it'll do it every now and then but rarely. Also there's the power off apps if that doesn't work
这个答案有帮助吗?
得分 1
添加一条评论
The only prob here is just the replacement but i advice u to send to some phone service
这个答案有帮助吗?
得分 0
1条评论:
Its all about power button
由完成的 分享
添加一条评论
on off battun not werke
这个答案有帮助吗?
得分 0
添加一条评论
There are multiple ways you can replicate the functionality of your power button in case yours doesn’t work anymore. Here I will tell you about the only two methods, excluding the obvious other one – having it repaired: turning your phone on and off with the help of apps and a neat little piece of hardware to help you do the same.
这个答案有帮助吗?
得分 0
1条评论:
Well, tell us then ...
由完成的 分享
添加一条评论
power key not working??
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cdude78411 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 18
总计 21,957
