跳转到主内容
An affordable smartphone by Nokia, using Windows Phone OS.
4 个问题 查看全部
Why is my battery not charging but the battery is working?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
my nokia 610 will not charge9have tried with two batteries.one of the batteries is brand
new.
这个答案有帮助吗?
得分 1
添加一条评论
vneomai, how do you know it's working? How do you know it is not charging? If it is not charging, how do you keep the battery working? If your phone works but the battery does not charge in your phone, you either have a bad cable, a bad connector or problems with the power management circuit on your phone. Start with the cable and work your way up from easy to complicated. You also want to try a new battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
vneomai 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 9
总计 885
