跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note 系列平板手机的第三代产品,于 2013 年 9 月 25 日发布。可通过型号 N9005 进行识别。
Unfortunately clock has stopped working
When i want set an alarm this message will show
Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
最有帮助的答案
I was also experiencing the same proble m but i found that the real problem is silent mode. If the phone is on silent mode then this error will occur when u set alarm. Simple solution is keep all the sounds on while setting alarm.
这个答案有帮助吗?
得分 2
1条评论:
Yeahhhh... This Work. Thanks a Lot Dude....
由完成的
添加一条评论
I too experienced the issue "unfortunately, clock has stopped" after updating my phone to Lollipop. I called Verizon and they told me to do a factory restore, which I did. The issue still persisted.
I just called Verizon Wireless tech support back. The guy had seen this problem once before and found a fix for it. I haven't seen this fix posted on any website, but it worked immediately. Please let me know if this works for you
Go to Settings--Date and Time--Select Date Format, and then choose a date format. Once I picked 'regional' the clock worked without the error "unfortunately, clock has stopped"
I tried clearing cache and doing a factory reset, and it didn't work. You don't have to do this if this if selecting a date format works. Please comment and let me know if this helped you. I'm curious if this will work across the board. Maybe even for phones other than Samsung Galaxy S4. I'm stoked!
这个答案有帮助吗?
得分 0
1条评论:
My dear friend, after i clear the cache and restart my phone i tired for that message and finally i reset factory in my phone but before this i create an backup from my device, and next when i test my clock i saw that it's working!!!
Thanks for your time
Have fun
With best regards
Masoud taghavi
由完成的
添加一条评论
Have fun
With best regards
Masoud taghavi
这个答案有帮助吗?
得分 0
1条评论:
I did that too and now it works! :)
由完成的
添加一条评论
Go to setting, device,sounds and notifications, interrupt,sound - select sounds. This solve the problem for my note3.
GK
这个答案有帮助吗?
得分 0
添加一条评论
My clock not working why
这个答案有帮助吗?
得分 0
1条评论:
Please find the my clock
由完成的
添加一条评论
添加你的答案
Masoud 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 10,738
