跳转到主内容
加入维修社区 - 创建账户
Monitor does not light up?
I can hear the startup chime when I turn it on and the light left of the lock release it on solid white when I turn it on. I can hear the chime when I tap the volume keys. I've tried using an external monitor with no luck but I think that has to be selected from my laptop. What else can I do to determine what needs to be replaced? Could it be my video card?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
Your best bet is the Nvida GPU issue to get a new logic board. See the link to this question then click on the Contact Center link.
Failed GPU Apple Program or Other Repair
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
It is possible that your particular computer falls in the batch of defective video card MacBook Pros. Here's the KB article describing it and what you can do: http://support.apple.com/kb/ts2377
I suggest taking it to an apple store with this information in hand, and they should be able to run a quick test to see if that's the problem. You'll notice that even if it's outside of the warranty period, they will still cover the repair for up to 4 years after the purchase date if this is the source of your problem.
这个答案有帮助吗?
得分 2
4条评论:
+ Good answer, looks like we were typing the same answer at the same time.
完成的
yeah same to you. I became a ACMT recently for my university so we could repair all our own apple computers and I've already seen this twice on the 15 inch MBP core 2 duos. Seems to be somewhat common actually.
完成的
I've sent in 3 in the last month and a half.
完成的
Thank you so much for your answer. I just called for an appointment to get it repaired. I mentioned the article about my laptop being in this batch of defective video cards.
完成的
添加一条评论
2 screens only large screen will light up
这个答案有帮助吗?
得分 0
添加一条评论
the screen on my laptop will not come on when i connect to a larger screen
这个答案有帮助吗?
得分 0
添加一条评论
i have two laptops one is a acer and the other one is a hp. and the monators will not lite up. i tried putting up to the light to see if i can still see any kind of inprint on the monators it looks like i can see microsoft. but i`m not sure my sight not so good
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TOMAS VASQUEZ 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 2,008
