Battery and charging issues
I have a MacBook mid 2007 2.0Ghz.
When I start the computer and it has finished starting up, I get the X in the battery symbol and it states that no battery is available, yet the battery is in the machine.
The charger is also green at this point too. If I remove the charger, the laptop turns off.
I have replaced the battery connector for a new one. Now when I plug the charger in, the light is orange. The laptop will not start up on the battery alone though. When I start the laptop with the charger connected, it still remains orange and the battery symbol sais it is charging and calculating the time to a full charger. After about 3 mins then charger then goes green again and the X comes back.
I have tried a new aftermarket battery and also the genuine apple battery. I have reset the PRAM and done the power drain with the battery and power disconnected, all to no avail. I have also re-installed the operating system.
Should I be looking at the magsafe connector next, or is there something else going on that I need to try first?
Any help would be appreciated.
Thanks
Is the X red or black? Please give us the last three figures of your serial number (located in the battery compartment).
由 mayer 完成的
Hi
Its a black X.
The last 3 digits of the serial number is Z5V
Thanks
由 matt loveless 完成的
Bump. Help
由 matt loveless 完成的
