跳转到主内容
加入维修社区 - 创建账户
雷克萨斯 ES 系列豪华轿车的第五代车型。
Headlights keep turning off.
My headlight keeps turnong off on its own while I'm driving. How can I tell if its just a bad bulb or the whole head unit has to he replaced (much more expensive!)? How and what part do I need to replace it with?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
3条评论:
I have the same issue. The passenger side or the drivers' side just turns off; every time I brake, one of them turns off. Often, while driving, it just turns off on its own.
由完成的
I have 2014 Lexus ES 350 have the same issue the headlight turn off on passenger side and turn off driver side while on driving at night
由完成的
I have a 2007 Lexus es 350 an when I turn my head lights on the driver side goes out right after turning them on . We changed the fuses but it still does it. What can I do about this?
由完成的
添加一条评论
3个答案
Are you saying one bulb only turns off and is it the same bulb?
Is your car equipped with HID headlamps?
If it is often what happens is the ballist starts to fail.
这个答案有帮助吗?
得分 0
添加一条评论
Check connectors, if they're OK, replace bulb
这个答案有帮助吗?
得分 0
添加一条评论
You should replace the adapter of the headlight.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
greenjacket99 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 4,786
