跳转到主内容
加入维修社区 - 创建账户
The sixth-generation Honda Civic was introduced in 1995. It retained its class-leading handling as it, along with the fourth and fifth generations, had front double wishbone suspension, the advanced independent suspension inspired by Honda's racing research.
Engine code for Honda civic
What dose engine code d0135 mean for 1999 Honda Civic
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Joeb, never seen a D0135, only a P0135 which means "Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)" To repair that I would start by replacing the oxygen sensor as well as checking the wiring harness to make sure it is not damaged.
这个答案有帮助吗?
得分 1
添加一条评论
I had quite an issue with my 1998 Honda Civic HX, told me the oxygen sensor was lazy, even for a new sensor. Turned out that the ECM needed more recent firmware, but an update was not possible. Ended up getting a replacement ECM which cured the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joeb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 855
