washer won't stop filling with hot water
Our He3 washer won't stop filling with hot water, even when the cycle is over. We have to close the hot water valve for it to stop. We are figuring we need to replace the hot water inlet valve but thought we'd check if there was anything else that could be the problem. The last load we ran, where the problem appears to have begun, had an error, flashing F during the cycle but no number that either of us remember. Upon clearing that, the cycle continued. Later in the cycle, the SUD error came up but the cycle kept going on its own. The problem then was that hot water continued to flow thru the machine, no matter where it was in the cycle. If there is something other than a faulty inlet valve that could be causing the problem, we'd like to know so we can check on it and not put in a part that won't solve the issue.
Thanks
