跳转到主内容
Samsung WB35F Camera Manufactured in 2014 by Samsung. Samsung WB35F 16.2MP Smart WiFi & NFC Digital Camera with 12x Optical Zoom and 2.7" LCD
7 个问题 查看全部
How do I stop my camera zoom from malfunctioning
A couple days ago, I was shooting some pictures in my drive way when the wind blew over my makeshift tripod and I ended it up not being able to turn on my camera because the screen said the zoom was not working properly please help I need my camera working!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
ThunderArt Comics just came across this question and I am certain that by now, you either have the camera fixed or are no longer using it. So, consider this an informational answer only.
Since your camera dropped, it is most likely that you knocked the lens of it's taacks or bendsome of the lens tubes. If you look at the lens head-on you can possibly to which side it may be leaning. You can try to gently push or pull the lens, while turning your camera on, into the proper direction. See if that will reseat the lens. Since individual parts are not available for this lens to complete a repair, you will most likely having to change the complete lens. There now is a YouTube video available that would have been a great guide for you at the time this happened. Of course, there are now also guides Samsung WB35F that would have helped you to at least get into the camera :-)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ThunderArt Comics 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 275
