跳转到主内容
加入维修社区 - 创建账户
Asus G72GX 于 2009 年发布,配备 17.3 英寸高清显示屏,纵横比为 16:9。
Disable touchpad on ASUS laptop
How do I disable touchpad on Asus Laptop?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Check your Function or "F" keys. One of them should have a graphic of the touch pad with a line through it. Hold down the Fn key and press this one to disable or enable your trackpad.
这个答案有帮助吗?
得分 1
3条评论:
tried this and nothing happened. I need to disable the touchpad because it's making my pointer icon jump all over the screen when my hand/wrist touched the pad while typing. help
完成的
Check if ur Asus smart gesture is installed.
完成的
I've having the same problem Brent D is having. When I'm typing my pointer is jumping around the screen. I can't get the touchpad disabled. I have no idea how to check for Asus smart gesture installation. Laura A.
完成的
添加一条评论
Fn + F9 used to work, but every windows update enables it again. This latest seems to have disabled this combination completely. It's very annoying and causing me to lose a lot of work.
这个答案有帮助吗?
得分 0
1条评论:
Hi If you are running Win10 have you got the latest ATK package and Smart Gesture software installed? Install the ATK package 1st before the Smart Gesture. Do not be tempted to install the other drivers. One problem at a time. If it ain't broke don't fix it!
Here is a link.
http://ivanrf.com/en/latest-asus-drivers...
See the 'Note' on how to install.
完成的
添加一条评论
添加你的答案
Nancy Heinonen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 21
总计 2,332
