跳转到主内容
加入维修社区 - 创建账户
1005HA 发布于 2009 年 6 月,以其“贝壳”设计而著称。根据操作系统、内部存储和电池容量的不同,该机型有多种版本。
Problem with my EEPC
I formatted part of a key USB my hard drive C: with Gparted. so I deleted lartition hidden.
I does not happen again to install Windows XP from a USB key because it tells me that it can not find C: drive on my EEPC.
Thank you for your solutions
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
So you deleted your hidden recovery partition? Then you cannot use the recovery option in the BIOS anymore.
"C:" is not a physical drive, it is the name ("drive letter") of a file system of a partition on a drive. A proper operating system installer should first give you the option on which physical drive to install. Then you may even create a partition of your preferred size. This will get formatted and named "C" as default. Then the installation starts.
I don't know what's on your USB key, but maybe you need to prepare it newly from a proper CD image. You may also connect a disc drive via USB and install from a disc directly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Didier 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 31
总计 526
