iMac "Core 2 Duo" 2.4 24-Inch (Al) completely dead. Help!
Dear All,
i had a bad luck to buy second-hand iMac from Yahoo Auctions Japan. It was (as I saw after all) indirectly described (in japanese) that mac stop starting. So, at home when I got my lively mac, opened box, got comp, plugged, pressed Power button, and saw nothing at all: no picture, no sound, no any movement, complete black silent. :(
Is any fuse inside I can replace, or power supply, or how to find a wrong unit??? (it's not a cable issue - 100%). Sorry, I'm just beginner. Will appreciate any advice.
4条评论
did you fix it? my imac have the same problem
== Update ==
JUST FOUND ONE DIODE IN POWER SUPPLY UNIT BURNT OUT...
NOW LOOKING FOR NEW POWER UNIT
由 Vitali 完成的
Hi Vitali, I have had luck with previous generation iMacs G5, but no luck with my 24' and 20' intel based iMacs.
由 andriy 完成的
Did you fix your iMac? I'd like to know if it was the power supply or the logic board . . . .
由 TommyJames337 完成的
TommyJames337, 8 hours ago
Yes, I did. Power supply was defective in my case.
由 Vitali 完成的
