跳转到主内容
加入维修社区 - 创建账户
IC Logic Board Chip Identification
Attempting to repair a water damaged logic board and found a very small 6 pin gull wing chip that has corrosion that I think is bad. The chip is marked K72X3 and is located just above the USB connector at the middle of the board. I have not been able to find anything at all ac IC with this number and have looked through all of the schematic pages and can't find a chip with this identification. Any help would be greatly appreciated.
Denny
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Denny, the component you pointed out is Q9441 which is a 2N7002DW-X-G diode in a SOT 363 package. Looks like you got some severe corrosion damage. Clean your board well before replacing the diode. You have some more isues around the LVDS connector and multiple other areas. Replacing this diodes may not fix your board, make sure that you check everything else as well. BTW the diode is part of the Display port connector circuitry.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Denny 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 975
