跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
iPhone 5c wont charge, dock connector has been replaced?
Hello
I have got an iphone 5c which simply wont charge, i have replaced the dock connector, and the same problem occurs, the phone works perfectly otherwise, and all of the other parts of the dockconnector like the jack port works perfectly.
Can it be a problem with the motherboard, and could cleaning the connection on the mother board with alcohol help?
I simple just don't know what to do, hopefully someone in here has some insight
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Jonas Paarup, replace the battery as well. If it still does not charge, and you are sure the replacement Lightning connector works properly, you are having issues with the power management IC on the logic board. This will be a very difficult repair and requires special tools and skills.
这个答案有帮助吗?
得分 0
1条评论:
I have already replaced the battery too. And i have tried 2 different Dock connectors, so i am pretty sure they work. I guess there is nothing to do then.
完成的
添加一条评论
添加你的答案
Jonas Paarup 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 127
