跳转到主内容
加入维修社区 - 创建账户
百思买(Best Buy)旗下品牌 Insignia 所生产平板电脑的维修指南与支持。
tablet will not turn on
it not comeing on and yes it is fully charged
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
5条评论
I purchased 3 tablets for my chandchilden. They will not charge at all. The screen remains black
完成的
I Lt doesn't turn on or anything I've been charging for 3 days know and nothing
完成的
My Tablet will not even turn on and the screen is still black, What should i do?
完成的
My tablet will not charge while in the charger. It will decrease the charge instead of the other way around so I'm not sure what I should do about it and it's like 6% I think right now not sure if I need a new battery or if there's a way to fix it I just wanted to let you know I asked you what I should do let me know?
完成的
i don't want to reset my tablet!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
完成的
添加一条评论
3个答案
已选择的解决方案
If all else fails you can try a hard reset which will wipe all your data and start you from new. This is done by pressing the start button and the up volume button at the same time . Hold them both down till the machine starts . you will see probably the android and then a selection menu . Use your volume to scroll up and down the menu . Select factory reset and then yes wipe data and it will reformat the tablet and it will start from new. Hope this helps.
这个答案有帮助吗?
得分 8
8条评论:
how do you remove the battery?
完成的
This one requires soldering to remove but if your hand with an iron this will help
Insignia Flex 10.1 NS-P10A6100 电池更换
完成的
It doesn't turn on should we charger it or what??
完成的
Or how long to take to turn on
完成的
It will not charge!?
完成的
显示更多的3条评论
添加一条评论
Try removing the battery. With the battery out hold the power button down for 60 seconds. But the battery back in and try turning it back on. If the light comes on the LCD screen could be ruined. Might have to change that. But doing the first step i said fixes quite a few issues.
这个答案有帮助吗?
得分 3
6条评论:
How to remove it
完成的
Yeah how do u remove it
完成的
Wow Tyler Black thanks so much this helped it totally worked i tried taking battery out but would come out but just took the back of the tablet off and did what you said and it came right on thanks
完成的
my tablet is fully charged but not starting
完成的
my iPad is not working because it has a little crack in the back and I'm clicking the power button for 60 seconds and then not working
完成的
显示更多的1条评论
添加一条评论
Check the place where you plug in the charger. Sometimes the prong inside gets a tiny bent. Wiggle it a bit with some tweezers and you should be good to go. I used to refurbish tablets and it happens with all brands. This may also work on your phone if you ever have the same problem.
这个答案有帮助吗?
得分 2
2条评论:
It is very annoying to reset your device and lose everything so try this first! Also to clean it a lightly damp q tip of alcohol will do the trick
完成的
How can you reset it if the screen does not open. It is pretty hard to reset when the screen is black.
完成的
添加一条评论
添加你的答案
jloza84 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 31
总计 47,185
