跳转到主内容
康柏电脑 所制造的上网本的修理和支持指南。
18 个问题 查看全部
just bought this netbook and it loads up in safe mode
Just bought this compaq mini 110c- 1100DX, and it starts up in safe mode
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
darliene parrish, update all the drivers, check device manager for any devices that show an exclamation mark and update those. Reinstall the OS if anything else fails.
这个答案有帮助吗?
得分 0
添加一条评论
Is it only starting in safe mode? If not, don't worry about it.
If it is, the first thing to try is to run system restore to restore it to an earlier configuration that, hopefully, will work. You can do so even in safe mode command prompt only mode by following these instructions from Microsoft.
If that doesn't do it, you may have to perform a repair installation as outlined here.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
darliene parrish 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 82
