跳转到主内容
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 个问题 查看全部
The rear brake hard lines
where can i purchase the hard lines for the rear?? for an 86 300e??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
The rear hard lines are standard size with bubble (not double) flares. The simplest/cheapest way to get this, assuming you don't want to buy a flaring tool or stainless lines, is to remove the line as best you can - if you have to cut it mark the proper orientation that the parts line up - and bring it to your local auto parts store or euro repair shop. They can usually cut, bend and flare a custom tube for you for a reasonable price. VW dealerships are everywhere and they use the same size and style tubing, btw, so they'd have it.
Alteratively, get a bubble flare tool like this one and get some appropriate size tubing and fittings and make your own. That bubble flare tool is a really good price - I bought basically the same one about 10 years ago and paid $400. Still using it.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Blake Martinez, you can get the pre-bend lines from your local Mercedes service center as well as places like this
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Blake Martinez 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 166
