跳转到主内容
加入维修社区 - 创建账户
Jawbone MINI JAMBOX 是一款小巧、便携且支持蓝牙的扬声器,它能在小巧的机身中提供高品质的音频。
Music not playing through bluetooth?
My phone is paired with the MINI JAMBOX over bluetooth, but I cannot play music. However, I can play music over the auxiliary cord, but not over bluetooth. Whats going wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
6个答案
最有帮助的答案
Have you tried a bluetooth reset or a software update? Here is a link to the soft reset: Jambox Reset and here is a link to the software update mytalk.jawbone.com
这个答案有帮助吗?
得分 3
添加一条评论
Another common issue with the JAMBOX MINI is "phantom auxiliary" connection. Your JAMBOX thinks it is connected over auxiliary, so you tries to play audio over that connection instead. Check if there is any blockage in your auxiliary port and take a look at our bluetooth troubleshooting page here. If you think this might be the issue, you should follow our USB / auxiliary port replacement guide here.
这个答案有帮助吗?
得分 0
添加一条评论
Be sure that the audio cable that you can use to physically connect your phone to the audio jack of the JAMBOX Mini is not plugged into the JAMBOX Mini. When the audio cable is plugged into the JAMBOX Mini's jack, it won't play via Bluetooth. Once you unplug that jack, the JAMBOX Mini will play the Bluetooth audio.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem, just make sure NO CABLES are connected to your JamBox at all
这个答案有帮助吗?
得分 0
添加一条评论
I have my Bluetooth connected to my subwoofer and it's saying it's connected at the top but I don't hear any music and I'm not really good and connecting
这个答案有帮助吗?
得分 0
1条评论:
How can I connect my Bluetooth and hear the song at the same time so I can hear it through my radio.
由完成的 分享
添加一条评论
My new jawbone jawbox didn't work, cause I can't hear the sounds on my speaker
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Noah Sadler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 27,217
