跳转到主内容
加入维修社区 - 创建账户
G4 Quicksilver 拥有 533MHz、667MHz、733MHz、800MHz、933MHz 和 1.0GHz 等多种频率规格。
Can my cpu be fixed
a capacitor fell off the cpu. can it be resodered?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Yes it can. You might want to check the value of the capacitor to be sure it is still good. I have had one drop off due to poor soldering. I was able to resolder it using a 25 watt soldering iron with a very small tip. I had to use regular 60/40 solder that melts at 360 degrees F. It worked. Just don't over heat the solder joint.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
madruler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 239
