跳转到主内容
Lenovo ThinkPad T400s was a laptop introduced by IBM for corporate and commercial use. The T400s was released along with the T500 in July of 2008. Similar models include the 400, 410, 420, 510, and other models in the ThinkPad T series.
5 个问题 查看全部
问题已关闭
Can I use a different watt power adapter?
I lost the 90W 20V power adapter that came with my T400s laptop. Could I use a power adapter from a T430S interchangeably? It is a 65W 20V power adapter.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Esther Chen, it will take a bit longer to charge your battery etc, but you should not have any big issues with that. Only thing you want to check is that it does not get to hot in case your T400 pulls to many amps.
这个答案有帮助吗?
得分 1
添加一条评论
sometimes, your power adapter wont work loner
这个答案有帮助吗?
得分 0
添加一条评论
Yes, both power adapters should work fine for the Thinkpad. However, there may be limitations for the 65W power adapter: the battery will take longer to recharge and it might not be powerful enough for certain types of usage (ex. watching a DVD while at the same time running HDD intensive applications).
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 155
