跳转到主内容
加入维修社区 - 创建账户
Acer Aspire 5738Z 由宏碁(Acer Inc.)于 2009 年发布。其主要配置包括:15.6 英寸笔记本电脑、英特尔奔腾双核移动处理器 T4200 (2.0 GHz)、3 GB 内存和 250 GB 硬盘。
Why is my GPU overheating
only Chrome or Firefox are open and still heating up to 70degrees with full screen youtube heating to 85...
SENSOR INFORMATION
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
Also: After a couple years (5+ in case of my Acer Aspire5500 series) the adhesive (white) paste between cpu and heat sink becomes brittle and deteriorates. It is user replaceable (AFTER warranty voids), and there are youtube instruction videos to guide you. Components are cheap to buy (Frys electronics, for instance) Best of luck
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
It turned out that my laptop doesn't havethe air cooling intakes cut out at the factory so there is only an exhaust hole and no place to get fresh air in. Check the bottom of your laptop and see if your laptop's air cooling vent is cut out.
Cheers!
这个答案有帮助吗?
得分 2
添加一条评论
Try to put something under the devices to lift it a little off the ground because the heat sink is located on the left side just below the device and the outside air field is small, I think.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
adnanomerovic92 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 1,381
