跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note II 是一款以大尺寸显示屏和针对集成式自收纳触控笔进行优化的软件组合而闻名的智能手机。
Cannot connect to wifi
my phone's wifi is not working
my wifi signal strength is very strong but it's not able to connect
the status shows obtaining IP address
and after a while it tells network disabled. Poor connection
I checked on the net they say it's because of the update of the phone original version 4.1.1 to 4.1.2 jelly bean, the update is causing the phone wifi connection go crazy
I checked for the solution, in many forums they showed to change the IP settings from DHCP to Static which I did and then after entering the wifi password there is no save option
I tried this way too..the link is below
https://www.youtube.com/watch?v=zyO66lqT...
the first way is dialing *#0011# but it's still not connecting
the second way was too confusing so I didn't try
I checked it online and I guess this problem does not only happen in note 2 but almost all the android phones
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
I have the same problem suddenly in a day. I reset my phone once and I downloaded the wifi fixer, diff., versions, it just does not work.
完成的
添加一条评论
6个答案
最有帮助的答案
my phone is not connecting to wifi and bluetooth
这个答案有帮助吗?
得分 1
添加一条评论
Hi Smriti
Have you thought about the wifi antenna being faulty and to try a replacement?
这个答案有帮助吗?
得分 0
添加一条评论
2nd Rssi is not available
这个答案有帮助吗?
得分 0
添加一条评论
disconnect then put your password back in. that what i did.
这个答案有帮助吗?
得分 0
添加一条评论
I can not connect wifi in my mobile
这个答案有帮助吗?
得分 0
添加一条评论
I would recommend replacing the WiFi antenna.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Smriti Sharma 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 23
总计 25,852
