ipad 4 is not charging or turning on
hi, i have an apple ipad 4 wifi which is not turning on or charging, i have tried different charger but its still not working, even it is not recognized by itunes
manubali811, besides different chargers you also want to try a different cable. If none of that works, consider changing the lightning connector. Use this guide for that.
这个答案有帮助吗?
hi, thanx for replying, can you tell me for what those 4 or 5 wires are there which are connected to bottom of logic board ner to home button flex??
actually while disconnecting them i accidently broked one pin(first from left side) and its track is gone so i can't solder it again
post an image of the damaged board and wiring with your question. 在已经存在的问题里加入图片 Lets see what you can do to fix it.
I can't believe the walk through has 27 steps! Just to open the screen. 😂
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 231
