跳转到主内容
加入维修社区 - 创建账户
GoPro Hero3+ Black Edition 可以通过型号 CHDHX-302 进行识别。这是一款发布于 2013 年 10 月的第八代摄像机。GoPro Hero3+ Black Edition 是一款支持 Wi-Fi 功能的 4K 分辨率数码摄像机。
Why is my GoPro freezing?
My GoPro Hero3+ Black keeps freezing when I try to use it? What can I do to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This is a common problem and generally requires you to reset the GoPro. You must first remove the battery and the SD card from the device. Then, replace the battery and hold the shutter button. If the GoPro turns on, power back off and insert the SD card. You may need to reformat the SD card again using the GoPro before using it again. For more answers visit the GoPro Hero 3+ troubleshooting page: GoPro Hero3+ Black Edition Troubleshooting
这个答案有帮助吗?
得分 0
1条评论:
Didnt work for me. I tried all the updates, hard resetting, tried different SD cards, tried brand new battery, nothing worked. Hard reset does nothing except puts all the default settings back on the cam.
由完成的
添加一条评论
添加你的答案
Chad Carlson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 31
总计 4,239
