跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Backlight problem on 5s
I think I need to replace the backlight filters. I've read plenty about where they are on the iPhone 5 but can't find anything on the iPhone 5s. Can anyone tell me where they are on the board and where I can buy them? Is this all I will need to replace or should I also replace the coil and ic chip.
Thank you in advance!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
You have micro soldering skills and tools?
完成的
添加一条评论
2个答案
已选择的解决方案
I'd check around FL24, FL25, FL26 as well as the capacitors C17, C243 and C18.
further explanation package size
这个答案有帮助吗?
得分 7
11条评论:
Thank you! This was exactly what I was looking for. Do you know where I can buy the filters and capacitors?
完成的
Looks like they are all in stock a digikey.com
完成的
Thanks oldturkey03. Is this the part for the filter? FILTER CHIP 120 OHM 3A 0603
完成的
Found it (I think) - FERRITE CHIP 220 OHMS 2.0A 0603
完成的
susan, the three filters are 240 OHM 0.2A 0.8 OHM in a 0201 (0603 metric) package. Available at places like this http://www.digikey.com/product-detail/en...
完成的
显示更多的6条评论
添加一条评论
Probably not the cheapest solution, but perhaps consider replacing the entire display assembly, digitizer en all. It's a Much Much easier job.
这个答案有帮助吗?
得分 0
1条评论:
I already tried that. I can see the apple logo, barely, using a flashlight pointed at the display, so I think the backlight filter is blown. I'm up for replacing it/them. Can solder, just don't know where they're located. Plenty of info on the iPhone5, not much on the 5s.
Thanks!
完成的
添加一条评论
添加你的答案
susan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 2,418
